woohoo !
Old May 27, 2012 | 12:09 PM
oange ss's Avatar
Default woohoo !
Couldnt find my other thread .Finally started it today, cant drive it till I get some more gas to weld in the BOV.
1964 Chevelle
LS1 (approx 9.8:1 comp)
T56
12 bolt w/ 3.42 gears
E85
Aeromotive FPR (44 psi base pressure)
-8 fuel supply
-6 return
2 intank Walbro 255 ( 2nd pump on 5psi Hobbs switch)
SD 80 injectors
Comp Cam 227/223 .610/.614 115 LSA
#317 heads w/ Lunati springs (home ported)
truck manifolds
2.5" hot side
Precision 39mm waste gate (12 psi spring, for now)
TC 78 w/ 1.15 A/R
3.5" downpipe to full 2.5" exhaust
LS9 head gaskets
3" cold side
Ebay 31x14x3 intercooler
LS7 clutch (for now, previously installed will change out later)
Old May 27, 2012 | 12:19 PM
93camaro_zzz's Avatar
Very nice setup! You have a full picture of the car? What kind of numbers are you looking for? I like the T56 too.
Old May 27, 2012 | 12:45 PM
oange ss's Avatar
thanx, 650-ish rwhp
This is last year after I got the Air Ride installed. I ditched that setup and am using their coil overs up front and stock springs in the back
Old May 27, 2012 | 11:01 PM
Build-it-Break-it's Avatar
VERY VERY VERY beautiful ride..... Im jealous......
Old Jun 18, 2012 | 04:10 PM
oange ss's Avatar
meant to post here insted of Hybrid:
did some tuning this weekend, injectors are @ 88% duty cycle, with 16* timing and seeing almost 14 lbs of boost with a 12 lb spring installed. Apparently my wastegate is too small for 12 lbs.
Old Jun 18, 2012 | 05:28 PM
Moter's Avatar
Looks good! should haul *** I used to have a 64 Chevelle....loved that car!
How is it that you have you fuel lines routed to and from the regulator? Kinda hard to tell from the pics. Where does your supply line come in?
Old Jun 18, 2012 | 05:53 PM
oange ss's Avatar
fuel supply starts at the rear of the drivers side fuel rail, crosses up front then to the regulator out of the rear of the pass rail
