6-Rib D1-SC and 10 Sec Times
http://forums.corvetteforum.com/zerothread?id=786457
I seen that car Sunday run 140mph sliding all over the track, damn good running car. I didnt look under the hood though so I dont know if the drive is modified but I'm sure it is..
Maybe that pulley with the spikes/teeth in it.
I forget who makes that...
Fixed Link to Post up top... had an error.
My friend is running 2.75 Reichard pulley on his SC'd viper with no belt slippage whatsoever and making 13psi only on his 540CID stroked motor. I'm going to call Reichard Racing when im going to a smaller pulley with my blower.
Well, some people won't believe this but here is my setup.
c5 - m6 coupe
- Stock ATI Bracket with D1 SC (4.65 6 rib pulley) 8-9psi
- Front mount intercooler with lowered radiator (original A&A design)
- Stock shortblock
- stage II heads with 71cc chambers
- 218/224 cam
- custom alky injection system and other fuel system upgrades
I have not had a chance to dyno it with this setup, but my 1 and only all out run at the track with this setup (they kicked me off for no cage) was an 11.0 at 134 1.8 60ft on drag radials bouncing off the rev limiter in 2 gears (on pump gas). I'm almost sure I could have dipped into the 10s with one more shot at it.
I would guess I'm making 600+RWHP my (42lb injectors are maxed out and i'm wating on the 60# mototrons before I dyno it). It pulls hard. I don't think I currently have any belt slip issues at all. Stock tensioner....
I'm not saying that I've done anything special here, just that the stock ATI bracket setup is good enough for 10s on the c5.
I'm pretty much launching off idle right now since I need to beef up the driveline a bit more and run ET streets.
I have seen almost 8.5psi out of my lowly little P1SC (stock motor/headers/cutout) in cold weather with a 3.2 6 rib RR pulley and I have not touched the belt in over 100 track passes and 2000 strett miles - no slip, no dust. I actually bracket race this thing and its amazingly consistant.
But if I added heads/cam and dropped the compression that would all change pretty quick
