408 turbo guys in here
Old Jun 5, 2012 | 10:08 PM
2002SLPSSCAMARO's Avatar
Arrow 408 turbo guys in here
im currenty knees deep in a full build from motor to suspension and everywhere in between... I wanna get some input and discussion goin on with guys doin a turbo setup on a 408... What turbo... Boost... Trans.... Rear gear... Fuel... So on and so forth... Maybe even get some track numbers would be cool to see... Let the party begin lol
Old Jun 6, 2012 | 05:34 AM
408COUPE's Avatar
What do you wanna do with the car...
Old Jun 6, 2012 | 07:50 AM
turbo iroc's Avatar
402 t6pt88
Old Jun 6, 2012 | 11:07 AM
Jefro6996's Avatar
No number yet for me... still putting everything back together. But im going with 408, GT91 T6 turbo, 4L80e from Jakes, most likely a 3.25 rear gear, and fuel is going to be E-85. Still need to talk to some of the sponsors on an adequate fuel system for E85 (most likely FIC 2000cc's and a large pump), but i wanna run 15-18lbs on the street and 20+ at the track.
Old Jun 6, 2012 | 11:12 AM
konceptracin's Avatar
Gt5088 t6
Old Jun 6, 2012 | 07:37 PM
Im doin a 2002 slp ss camaro 408 with 317s that are ported all new internals a t6 turbo... Not sure on which model just yet...wanna run around 20-25 lbs on 93 or race gas and meth...th400 trans with a 3200 stall and a 9inch with 3.50 gears...gonna run a 12 point cage and do all tublar suspension front to back.... Hoping to make in the area of 1200 hp...mostly a track car but i will take it on the hot rod power tour for sure...that y im not goin e85... Just cant find it out and about enough... Plus im only at home 8 weeks a year since i travel for buisness so it cant be a crazy car and it wont bother me at all lol
Old Jun 6, 2012 | 07:38 PM
It can be a crazy car lol.... Correction
Old Jun 6, 2012 | 09:21 PM
TheLS1Lover's Avatar
Boost is restriction, your looking for a certain CFM. Use that to match the Turbo you need.
GT91 Turbo from Jose at Forced Inductions, 1.08 A/R.
You will DEFIANTLY want to run Methanol, since you're not running E85.
Old Jun 6, 2012 | 10:33 PM
KILLER-LS1's Avatar
Im on a 408 & GT91.. check out this thread for pics, videos, and dyno sheets!
https://ls1tech.com/forums/forced-in...eo-inside.html
Old Jun 7, 2012 | 12:22 AM
Love to see u guys chiming in on this... Hope this will be a great thred...im on the fence between the 91 and the 94... And the 1.08 and 1.32... Just because i wanna have room to go with more power down the line without changing the turbo... Its up in the air... But ur right by matching the cfm thanks for the advice...
Old Jun 7, 2012 | 12:29 AM
Killer awesome car bro... I have folled ur car for a while love the paint job...i dont think the 202.5 is where im headed but congrats...im only 24 and i hoping the car will be in the 8's with the work im doin...
Followed*
Old Jun 7, 2012 | 12:33 AM
Quick? what fmic can i run to support the 1000+ hp ill be making. ?..i dont wanna run atw i wanna run ata... But i havent seen one for ata that will support that kinda power.. I will be running meth for sure so does that help with this??... Still trying to learn a few things as i go
Old Jun 7, 2012 | 11:59 AM
The GT91 is $1600.. It will meet your power goals. And you can always change the exhaust housing. You don't have to change the turbo.
Look into Bell Intercoolers or one of Shearer Fabs Intercoolers. Any good core 4"+ Thick would be nice.
Old Jun 7, 2012 | 08:03 PM
Thanks for the pic turbo iroc
Old Jun 22, 2012 | 11:26 AM
LT1TA's Avatar
Also 20-22 lbs on 317's will be close to lifting point. Be careful either way. I've been researching and the consensus is 16-17 lbs safely on stock heads
Old Jun 22, 2012 | 10:03 PM
TrickrTreat's Avatar
11-12 lbs on a ls2 402 , 71 mm turbo .....yes 71 , 4l80e , 3:23 gears ,3600lbs , straight 93 octane , A2A intercooler , 317's , no meth. 680 hp , 9 sec 1/4, 400+ miles a week.
