Pulley Size Question
Old Jun 8, 2012 | 07:12 PM
Saleen S7 TT's Avatar
Default Pulley Size Question
Coming from 6000 ft NV to 1000 ft MN, what size pulley should I run or should I keep it the same and adjust the fuel/air ratio? Previous owner believes it is currently a 3.4" pulley.
Here are the specs:
• Stock short block
• Patriot P&P 243 heads
• Thunder TR224-112
• Mac Mid headers with off road Y pipe and Gibson cat back
• BBK 80mm TB
• P1SC Procharger with Dual inter coolers runs at 7 PSI
• LS6 intake
• 60lb Motrons
• Racetronix fuel pump
• Performabuilt Level 2 with Performabuilt billet 2800 rpm converter Trans has less than 500 miles on it
• Good trans cooling system
• Strange driveshaft
• Moser 9" w/ 3.70 gears Rear has 4k miles on it
• Chrome C6 staggered wheels
• Toyo Proxes 4 245/17 front
• NEW Nitto 555 Drag Radials on rear 275/17
• New Bilsteins all the way around
• Strut tower brace
• BMR torque arm
• BMR PHB
• BMR LCAs
• Mac weld in subframe connectors
• NGK wideband mounted in-car
• Autometer fuel pressure and boost gauges in pod in pillar
Thanks for any input!
Old Jun 10, 2012 | 07:05 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I replied to your pm yesterday. You'll have to let me know what you end up deciding to do. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
