PT 7675 guys lets see your numbers
Where do you think a squareport mild cam 370 will put the power? I like how this turbo just carries peak power. Not buliding power fast and falling on its face because of a baby ex. Wheel
I hope to have it finished up and on the dyno next month sometime. I hope to make 680-700 on 10-11 psi and 830-850 on 17-18 psi.
My power goals are only 6-700 whp. 6 speed. Will make for a fun street car. I am not going out trying to make 1000+ I feel it will be plenty efficient for my purposes seeing how mostly everyone is satisfied with regular 76/68 combinations. This turbo might just give you the edge when everyone elses exhaust gets backed up you will still be making power and if the compressor is all done your not falling off as bad because the exhaust is still getting out that much better. You are not just making more intake pressure because your exhaust is plugged. (my old problem) A few millimeters on a round outlet makes all the difference in the world in terms of flow. It exponentially increases.
If this turbo doesnt give me the big end I want I will just go to a t6 s480 in winter and be done with it but I really have a feeling the 76/75 will make for a great street turbo esp with a 6 speed.
This is through a JW glide and I figured it out last year w/ my logs mph/rpm im losing about 5.5% through the converter.
Unfortunately I lifted a head and have to take it apart and fix it.
Im running E85, atomizer 160 injectors, TU1 cam,
