Simplest catch can setup
Currently, I have a vented Moroso catch can (single -12 inlet). I bought a -12 bung to weld into my valve cover with some -12 fittings and hose. Anyway, can pretty much everything else from the valve covers/intake just be capped off? I was planning on welding the bung into the hole in the driver's side valve cover. I do not have an intake on my turbo, it will be open.
I have a 2005 L33 with an LS6 intake.
To the OP I have an LS6 valley cover if you are interested. Has the breather port on the front and clears the TB.
PCV's and all that may offer benefits, but add complication. Simple is good in my book
I vent both valve covers and have 2 x -10 in the valley all into a large can which then returns any deposits back into the oil pan.
Fit and forget.
