Turbo cam help!
Old Jun 16, 2012 | 08:41 AM
6togo's Avatar
Well not having a ton of luck with this task but from the recommendations so far i am leaning towards the 242 242 .625 .625 115LSA cam my builder suggested anyone know how that would be in a 427 it said to be a agressive cam but im what size motor? and will it be steetable/reliable enough to have fun?
Old Jun 17, 2012 | 09:03 AM
6togo's Avatar
Bump!
Old Jun 17, 2012 | 09:07 AM
Bigtoyz's Avatar
if it is a boosted motor why isnt the duration on the exhaust side more? From what I have read it is better to have at least 20 degrees more on exhaust to make better boost.
It is a pretty radical cam for a boosted motor. Duration of a NA cammed engine.
Old Jun 17, 2012 | 09:58 AM
6togo's Avatar
From the reading i have done it seems it could go either way some builders like matching #'s some more on the exhaust. I dont know how radical it will be on a 427 which is why i was hoping someone with a similar cam would chime in and clairify!
Old Jun 18, 2012 | 10:25 PM
6togo's Avatar
Well i had Patrick G spec a cam for my build here is what he came up with=
231/235 .598/.610" 116LSA +4
Old Sep 25, 2015 | 11:38 PM
Tjs434's Avatar
Default Cam help
LSX 434 with fully ported LS3 heads cam chosen by builder 625/625 242/242 115 lobe seperation . Was wondering if anyone knows much about this cam Hiwards part # 190305-15
Old Sep 25, 2015 | 11:40 PM
Tjs434's Avatar
Default Cam
I went with this same cam and Hiwards did the grind was wondering if you went with it as well . Howards part# 190305-15
