2005 LQ4 boost ?
Old Jun 16, 2012 | 07:06 PM
sharpshooter's Avatar
Default 2005 LQ4 boost ?
After seeing some jy 5.3 and 4.8 live with 18-22 psi of boost, what can a stock LQ4 be run up to using 93 and 50/50 water-meth?
Old Jun 16, 2012 | 07:54 PM
stangtrader's Avatar
I have run 14psi quite a bit on my lq4 on a e30 mix, ran it on 18psi before but have not yet again,as long as you have a good tune and all the saftey you can add 18psi is doable
Old Jun 16, 2012 | 10:13 PM
a4ls2goat's Avatar
What size turbo?
I plan on running 15-17 psi on my 2005 lq4 with a gt45 on dual nozzle meth .. only gona run 10 degrees of timing though.
Old Jun 16, 2012 | 10:17 PM
TheLS1Lover's Avatar
There is really no limit. It will brake at some point. I say boost it till you get the numbers you want then see how long it lives lol.
Old Jun 17, 2012 | 07:35 PM
86lxnotch's Avatar
should do pretty good with meth, my sig is were im at with just a fmic on pumpgas
Old Jun 18, 2012 | 12:02 AM
Originally Posted by a4ls2goat
What size turbo?
im running the on3 t76
Old Jun 19, 2012 | 09:02 PM
AlterEgo's Avatar
How long have u been running 10psi of boost on that on3 turbo?? What size is it??? Lastly, will you help me tune mine if I get me a on3??
