Borg Warner K31?
Old Jun 21, 2012 | 06:41 PM
sandeggo's Avatar
Default Borg Warner K31?
I am piecing together turbo parts for a blow through setup on my 5.3l. I am already setup for carb. Someone I know has a pretty good deal on a BW k31 p/n 172143. I am having a hard time finding info about the turbo and if it will work for my application. Any input?
Old Jun 21, 2012 | 07:37 PM
SSZ's Avatar
SSZ
Have you seen the turbo first hand and is there a tag on it? Is there a number for the A/R on the compressor or turbine housing at all? Do you know what it came off of?
Old Jun 21, 2012 | 08:17 PM
sandeggo's Avatar
waiting for further info but heres 2 pics
Old Jan 15, 2015 | 02:35 PM
11.50fox's Avatar
I am wandering about this turbo as well. They put this turbo on c12 cat 726 cube diesels motors that make 600 hp.
Old Jan 15, 2015 | 05:45 PM
IronBlocked's Avatar
That looks tiny
Old Jan 15, 2015 | 08:24 PM
11.50fox's Avatar
the one i have are 66 a/r and are 71mm..whit billett wheels
Old Jan 16, 2015 | 08:17 AM
cptinjak's Avatar
It's the old school bearing setup which is not as reliable as the modern Borg units. The turbine is slightly larger than an s300. An s400 with the same size compressor could easily make 100hp more. We made a compressor wheel that fits it and helps some.
If it's free it'll work, but there are better options.
Jack
