got a leaky head gasket, help with options
what should i do?
just pull the one head and have it surfaced a min amount and reuse the cometic?
pull both heads and surface and use some felpro's($26/pair and local)
or do both heads but with some stock mls gaskets(
~$200for the set with bolts that i dont need, thats the only way i can get them)i will be hiting this motor with a t76 next week
if the gaskets look shady dont reuse them if the heads look bad, get them fixed.
i think you can order just the GM mls gaskets with out the bolts.
if your cometics are damaged call them up , thell probably give you a new set free like they did me.
here TR sells the 6.0 mls gaskets for $30
http://www.thunderracing.com/catalog...d=353&pcid=157
