Boost Reference Reg
Old Jun 25, 2012 | 11:53 AM
HexT's Avatar
Default Boost Reference Reg
Wasn't sure if this should go in NA discussion or boosted discussion.
I'm building a LS combo for my car that will be driven NA until next season at which point I'll be going blow thru on E85 with a Procharger. I'd like to buy parts once so I'm ordering the Magnafuel ProStar 500 pump kit that comes with a regulator. My question is can I use a boost referencing regulator and plug the boost port until I add the blower? Or would I be better off using a smaller regulator and just upgrading to the larger, boost referencing one later?
Old Jun 25, 2012 | 01:53 PM
KILLER-LS1's Avatar
yes, you can still use the ref. regulator. You can even leave the vacuum line hooked up to it. Its no different that a turbo car driving around without going into boost.
Old Jun 25, 2012 | 02:04 PM
HexT's Avatar
Exactly what I needed, thanks!
