oil cooler with turbo motor
Old Jun 25, 2012 | 09:13 PM
Blown02Camaro's Avatar
Default oil cooler with turbo motor
Was wondering how many have ran an oil cooler with a turbo set up.
I Would like to know how you like it and if it is even worth it for a car that will be driven on the street and some pics of how you plumbed it.
Old Jun 25, 2012 | 09:16 PM
tt383lt1's Avatar
i just ordered one for my car/ on a turbo car you have to run a oil cooler or the oil will get to hot. my oil temp was 250 befor i put the cooler on. i will have it on in a couple days. its should lower my oil temp about 50 degree. i bout a heavy duty oil cooler. there about $150 for a heavy duty one
Old Jun 25, 2012 | 09:35 PM
With your set up.. are you having the oil go through the filter first, then to the cooler then everywhere else?
Old Jun 25, 2012 | 11:34 PM
tt383lt1's Avatar
i have a oil adapter with 1/2" output and input. then a 1/2" hose going to the huge cooler and back to the oil adapter
Old Jun 26, 2012 | 11:07 AM
Danny's Avatar
How are you guys plumbing your oil coolers? I was planning on using the stock oil lines from a C6 Z51 Vette. Just like this one.
http://forums.corvetteforum.com/atta...es-2193_1_.jpg
It mounts right where the oil block is at. My only concern with that is that it might lower the pressure on the oil that's feeding the turbos.
What setup do you guys have?
Old Jun 27, 2012 | 01:09 PM
This is what im trying to find out... The biggest question I need answered is how to plumb the whole thing so that the oil goes through the filter first, then through the oil cooler... Modular turbo makes a piece that has already been drilled and tapped for the oil feed for the turbo plus it has a magnet to catch any fin metal pieces... Im looking for the piece to allow me to relocate the oil filter somewhere else...
I was looking at one of these hoping it'll work
http://www.improvedracing.com/engine...34db58749e2ad8
Old Jun 28, 2012 | 08:25 AM
Preston99WS6's Avatar
Lingenfelter sells a nice adapter is 10AN for the supply/return to the cooler has port for the turbo oil line and a port for a oil temp senser, running one on mine now, then just pick up a 10AN cooler and hoses cost's about 250 for it all.
Old Aug 25, 2015 | 05:47 PM
patman7800's Avatar
Do you have a link for that?
Old Aug 26, 2015 | 03:47 AM
stevieturbo's Avatar
Find out whether you even need one first.
What sort of oil temps are you seeing ?
Old Aug 26, 2015 | 10:36 AM
Trl_ws6's Avatar
My build isn't complete yet but I went with an improved racing piece into a derale cooler with electric fan with -10 hoses.
Old Aug 27, 2015 | 10:19 AM
Black_Sunshine_99's Avatar
This is what I'm considering. Got a couple guys on here running it without issue.
http://www.ebay.com/itm/25-Row-Engine-Oil-Cooler-Kit-Sandwich-Plate-For-BILLET-LS1-LS2-LS3-LSX-VE-HSV-/191584985323?hash=item2c9b5ae0eb&vxp=mtr&rmvSB=true
