Lets talking launching with boosted cars
I’m a blower guy coming over to the turbo world with very lil experience with turbos.
my f1 gto could never get anywhere close to seeing positive pressure in the manifold, I know the blower will act different but how does the turbo make any boost with bov being open as I dont see how the car could ever see enough throttle on the foot brake to build boost on the line.
Please help me understand how you build boost on the foot brake, with out pushing through the brakes
OP try your 3 step(I'm guessing this is the one on the footbrake) at 3200 and get 2-4psi built. Set the 2 step(transbrake rpm limiter) at 3600-3800rpm and leave on 6-7psi.
As Dave was saying I don't know how you have your tune set-up and if you're just using the main timing tables for timing or if you're using some of the other adder tables that can add timing only during set circumstances in the ECU so I don't know how much of a spread you will need between footbrake rpm and transbrake rpm to get that boost built. Most cars that run race gas that can get aggressive with timing can have it all built within 5 seconds. You being on E85 you can most likely do the same as them unless your camshaft is stupid early on the IVC event.
Let me know if you have any more questions. I think you have a good running car and that it wont take much more to get it into the 5's.
On a 1.29 sixty what is your wheel speed at 0.50, 1.0 and 1.29 ?
Charge pipes,, and DP are double wrapped. 2.25" charge, and 5" dp
Let's say 1.30 is the goal. Back in the day when I had my combo I really didn't know how to tune it, but helping on Andy's car I have a better sense of how it all relates.
What size turbo is that, I looked it up but is it a 94mm T6?
I think you want to leave on as much power as you can hook PLUS whatever rpm helps you get into your power band. If for example that turbo is laggy and doesn't turn on until 5500, you'd want to leave higher rather than lower rpm-wise.
The rear tire size, rear gear ratio, engine torque, converter, and electronics all play a role in the time delay from when you release the TB and when you see wheel speed.
As long as he can build enough boost at a low enough rpm that when he releases the trans brake flashes it into it's power band it will leave just fine and won't be leaving much if any on the table.
I've always found letting the rpm's run up to the converters lock up point is faster than loading it up on the transbrake and letting it bog basically when it leaves or flat line the rpm's for 60-80' and then the rpm's rise.
Adjustable shocks?
Are you using a two step?
I have Hal QA-1 single adj. all around with the rears on 2-4 depending on track cond. and the fronts on 3-5.
No two step.
If you had a two step and were able to launch it around 3200-3400rpm you'd have some flash in the converter allowing it to flash to the lock up point of the converter you are using and accelerate a lot faster and not have that lag or flat spot for however long it does.
http://youtu.be/ZiD-KB4WNXw
