procharger friendly cams?
DSchmittie1 on here ran a forged ls1 with a D1 procharger for a while, then switched to a turbo and ran that for a while until he bent the stock crank. He was making over 800 at the wheels. He bent the crank before he hurt the block.
Tune is usually the source of the destruction of a fully forged LS block. Your successes you hear are of proper block prep and proper tunes. The others are a lack of. Perhaps the rare occurrence is from bad luck
I would not question a 347 with 15+ of boost if properly prepped.
Now going to run 15lbs with the F1C. it is built to handle it and I have a good tuner.
OP I say you should give Futral a call so they cam spec a blower cam out for you. If you wanna pm me I can tell you the specs of mine and discuss the results I have had on a smaller D1SC.
