Head bolts or head studs??
Old Jul 29, 2012 | 12:53 PM
speedfreak2685's Avatar
Default Head bolts or head studs??
Im doing a somewhat budget build on a motor. It will be a 370 with a D1 with a 3.4 pully so it will be seeing some boost. Maybe 16-17# I would think? Anyways, im debating on head studs or head bolts. Im trying to save money where I can but I dont want to save $150 somewhere to regret it later if you know what I mean. That being said, will arp head bolts work or do I need to stud it and why? I like the idea of haveing bolts for the rare instance of being able to take the heads off with motor in the car if need be. Other than that, its just about the money.Im not sure what the combo will make but I would assume 750 wouldnt be out of the question. Heads will be 317's.
Old Jul 29, 2012 | 02:07 PM
MUSTANGBRKR02's Avatar
Studs.
Heads can still come off with it in the car.
Old Jul 29, 2012 | 03:15 PM
KILLER-LS1's Avatar
Studs have a much better clamping load on the head. You can still remove the heads. Worst case scenario, you have to unscrew the studs by hand after you remove the nut. Takes an extra 10 minutes....
Old Jul 29, 2012 | 03:25 PM
Makes sense. Thanks!
Old Jul 29, 2012 | 03:44 PM
vmapper's Avatar
Studs.
(boost depends on cam and several other factors as well such as RPM, elevation)
More so, is the crank pulley size... if your using a 7" or 7.4", 17 is not going to happen. Probably require 8+ inch custom
Old Jul 29, 2012 | 04:43 PM
stock48's Avatar
9 Second Truck Club
Haven't ran the bolts but i've heard of 3 people in the past 2 mos snaping them off while torquing. I've got a set here that are going back for studs...
Old Jul 29, 2012 | 08:22 PM
RacerXLs1's Avatar
Another vote for studs just spend the extra money..
Old Jul 29, 2012 | 09:57 PM
JAX04's Avatar
Ive not used the studs yet, but wish i was...
Ive used bolts in both the GTO and the Mustang now, torqued to 90ft/lbs.
But the truth is the truth, studs clamp better.
Old Jul 29, 2012 | 10:01 PM
a4ls2goat's Avatar
ill say this, its scary torquing down the stock TTY bolts.
Old Jul 30, 2012 | 12:04 AM
I8UR4RD's Avatar
1/2 head studs here with .750+ decklid!
Old Jul 30, 2012 | 12:35 PM
93camaro_zzz's Avatar
Very satisfied with the ARP head studs. They are worth their price alone for the fact of, that you can reuse them over and over. I just consider an 100% necessary part for building any FI LS motor.
Old Aug 11, 2012 | 01:53 PM
JoshuaGrooms83's Avatar
are they bolted the same as the bolts? or do they have their own torque specs and passes?
Old Aug 11, 2012 | 01:58 PM
Burken01's Avatar
Why do people always think studs are harder to take out over bolts in car?
They are easier IMO
Bolts suck
Old Aug 11, 2012 | 02:32 PM
They have a torque spec that is given by ARP as 80ftlbs. Same torque sequence though. I always do 85 though for torque wrench innacuracies and for safe measure.
