The little 5.3 that could.
Old Aug 27, 2012 | 08:06 AM
Bobsmyuncle's Avatar
Originally Posted by SSZ
Wow, great numbers. What are you tuning with? Congrats!
Hp tuners, FIC 114#, stock ecu
Old Aug 27, 2012 | 08:12 AM
Originally Posted by typhoon1015
very nice, good numbers, what kinda of fuel pump/pumps are you running?
One aero 340 in the tank, -10 out of the top of the tank, new holley billet dominator dual pump, 12-1400, rated to 975hp at 60psi. And the 340 is rated at like 400hp. They tee together and go single -10 to the front. It's barely enough pump, when the car was 9.6:1 air fuel the first few pulls, the pressure would rise to about 70# then drop to 65 or so, butafter leaning it out to 11.4-11.6, it was demanding alot less obviously, and didn't drop pressure.
Old Aug 27, 2012 | 08:56 AM
N2OBaby's Avatar
Dang thats Cook'n there.
835+HP from 325 CID!!!!!
Old Aug 27, 2012 | 09:15 AM
Cam72aro's Avatar
Nice. . . I take it you got the overheating problem taken care of?
Old Aug 27, 2012 | 01:03 PM
Pretty much, it'll overheat in stop And go traffic if it's above 90* and takes about half hour of it
At night time recently, I it 65* out, it'll run like 195-205
Old Aug 27, 2012 | 01:06 PM
Yea I will eventually go bigger, and mainly bc I need a bigger bore for a better cylinder head. Nobody believes what the 5.3s can do, and do it better than the 4" bore stuff, the heads stay down alot easier on these. We will see what the future brings
Old Aug 27, 2012 | 02:04 PM
Ryans99ls1's Avatar
nice numbers man. after seeing the setup in person im not surprised it made that much power haha. that turbo is massive.
Old Aug 27, 2012 | 03:48 PM
Thanks man, it's gettin there, needs the rear gear still.
Old Aug 28, 2012 | 09:26 AM
slow67's Avatar
Gingervitis Addict
Originally Posted by BLWN1
4788 is the largest 88? Was unaware... Nice setup.
No, the largest/biggest/baddest 88mm currently is the Precision X275 large frame 88mm.
Old Aug 28, 2012 | 10:42 AM
K STYLEZ's Avatar
Damn that's awesome. I'd love to see the graph overlayed with RPM vs. MPH tho. Any chance you've got that too?
Old Aug 28, 2012 | 10:48 AM
JAX04's Avatar
Nice work! And great results, send that 5.3 my way, im staying small cubes! Good to see what the RPS combo can do! Thanks for the update, turn the boost up, im very interested to see this thing at 30+
Old Aug 28, 2012 | 11:25 AM
  #32
trav-tech's Avatar
Blwn1. Are those precision turbos the biggest baddest turbos before or after the turbine wheel shears off and flys thru the side of the exhaust housing and or the fender?
Old Aug 28, 2012 | 06:35 PM
  #33
lol, gotta love it.
Old Aug 28, 2012 | 06:42 PM
  #34
thts fine. u want to compare a billet pro mod type turbo vs my journal bearing 1300$ unit. thts fine. too bad theyre both rated at 1600hp.
Old Aug 28, 2012 | 06:43 PM
  #35
7200rpm = about 125mph
