SD vs MAF
Old Aug 28, 2012 | 02:32 AM
1toofastlt1's Avatar
Default SD vs MAF
I have a 97 camaro lt1 with a v7 ysi. My question is if I'm going to dd my car what would perform better, a speed density tune or a maf tune? I want to be able to drive the car anywhere without any issues.
Old Aug 28, 2012 | 06:21 AM
dschmittie1's Avatar
Iknow lots of SD tuned cars that are daily driven and driven all over the place.
Old Aug 28, 2012 | 07:21 AM
Sweet_SS's Avatar
SD all the way. My last two vehicles were tuned on SD.
Old Aug 28, 2012 | 09:02 AM
ToxicWS6's Avatar
Not tryin to thread hijack but very interested in same question, but with ls1, what all is needed for a SD tune vs maf, 3 bar map?
Old Aug 28, 2012 | 09:18 AM
All that is needed for a SD tune is either a 2 bar of 3 bar map depending on what OS you want to put in th PCM.
I am currently running a 2 bar map and have a 2 bar OS from HPtunners in the car. I will be switching to a 3 bar Map and 3 bar OS over the winter
Old Aug 28, 2012 | 09:50 AM
Sweet_SS's Avatar
^^^ I'm with this guy. I to am running the GM 2 bar map. I also have HP tuners and am on the 2bar OS.
Old Aug 28, 2012 | 10:24 AM
onfire's Avatar
Coal Mining Director
I run both. Over 580ish enging hp , SD rules IMHO. Under 580, I still use a maf.
Old Aug 29, 2012 | 12:55 AM
Preston99WS6's Avatar
I run the 3 bar EFI live OS, car runs great on the street.
 Michael S. Palmer
Old Aug 29, 2012 | 01:40 AM
BottleFedZ346's Avatar
Another vote for SD!
Old Aug 29, 2012 | 03:13 AM
if its in SD does it matter if I tune at sea level then head up the mountain for the weekend. I heard it might run bad
Old Aug 29, 2012 | 07:50 AM
1sick-Z's Avatar
I run SD as well. I have no issues besides warmup. It starts looking for a MAF and runs like crap the 1st 5-10 seconds of startup than finds idle.
Other than that I am more than happy with it.
Old Aug 29, 2012 | 12:03 PM
89ROC-Z's Avatar
SD is fantastic. It's all in the ability of the tuner to get it correct. With a maf you either have a huge restriction, or buy a $$$ maf. With SD you can have 4" all the way. Only restrictions in my intake setup is the IAT sensor, and a n2o nozzle
Old Aug 29, 2012 | 05:02 PM
JaYZeig's Avatar
my trans am has a 3bar sd tune, cant even tell it dont have a maf.
Old Aug 29, 2012 | 07:12 PM
Do you guys ever drive in high altitude compared to where it was tuned?
Old Aug 29, 2012 | 09:16 PM
Also if I go SD will I need a 2bar or 3 bar map sensor? I wont run more then 20psi. Does anyone have a part number
Old Aug 30, 2012 | 10:19 AM
ibex37's Avatar
im interested as well, any one with input about driving at sea level and taking the car to a higher altitude?
Old Aug 30, 2012 | 12:58 PM
Adam86's Avatar
2 bar SD tune on mine. Running great so far! A good tuner is key.
Old Aug 30, 2012 | 03:32 PM
milkplus's Avatar
A bar of pressure is roughly 14 PSI (atmosphere at sea level).
0 PSI of boost would be roughly 1 bar. 14 PSI, 2 bar. 28 psi, 3 bar.
At least that's the way I understand it. I'm not sure if there's a 2.5bar OS but you're probably better off starting with the 3 bar.
If you have a 98 ECM like me, you're stuck with the 2 bar OS (at least through HP).
Old Aug 30, 2012 | 03:47 PM
wheeljunky's Avatar
Actually a 2 bar will read -14.7 to 14.7psi . Your car has vacuum till you go into boost. A 3 bar is from -14.7 to 29.4 psi.. like you i have a 98 PCM. 2 bar is the highest i can go. I'm running 15 to 18 pounds of boost. but i can never hold my foot into it to ever see those numbers.
Old Aug 30, 2012 | 03:48 PM
KILLER-LS1's Avatar
btw, you can get a 2 bar to fit in the factory spot, the 3 bar sensors do not. You just run a vac line to the sensor and zip tie it somewhere
Im on a 3 bar SD tue and still get 20+ mpg
