Need help with fuel system
Old Apr 6, 2004 | 03:46 PM
Inspector12's Avatar
TT-TECH Veteran
Default Need help with fuel system
02z 6SPD with TEA 6.0Lw/73-75cc chambers with 224/581 230/591 114+4 and a Vortech G-trim with a 2.65" pulley with 50# bosch injectors and the (50GPH@70PSI) T-Rex in line pump that comes with the kit and I want to know what if anything should I do about my fuel pump situation? I am guessing around 600 + HP? I don't know if that will be enough? Any info you could give me would help me decide what to do before I get it tunned ETC... Thanks in advance.
Jeff
Old Apr 6, 2004 | 04:03 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sounds good, you might need to upgrade the intank pump though...
Old Apr 6, 2004 | 04:27 PM
TT-TECH Veteran
What would you suggest ETC... The guys at RC eng. said I was border line right now and another vendor told me that the T-rex (Inline) would just restrict any thing bigger that I put in the tank ETC... They suggested the 340w/the hot wire set up. I just read a post where some one was running out of fuel with that same setup so I am at a loss as to what to do with out running a bigger line (8) ETC...
Old Apr 7, 2004 | 02:55 PM
TT-TECH Veteran
Ttt...
Old Apr 7, 2004 | 02:58 PM
Nasty N8's Avatar
One Walbro 340M hot wired should support 600rwhp. Leave the inline out of the mix.
Nate
Old Apr 7, 2004 | 03:06 PM
BIGBOS's Avatar
Get some Twin 340's in the tank or a single inlike 420LPH pump
