recommend me a cam?
Old Sep 1, 2012 | 11:02 PM
LILHEMI's Avatar
Default recommend me a cam?
motor will be a stock 5.3 with a gt4294 turbo pushing around 15 psi initially. th400 around 3800-4000 stall probably. was looking at these cams from comp.
http://www.summitracing.com/parts/CCA-54-444-11/
http://www.summitracing.com/parts/CCA-54-467-11/
would these be good OTS cams for what im putting together?
if not can someone point me in the right direction. thanks in advance.
Old Sep 1, 2012 | 11:07 PM
Wicked69's Avatar
Those are just a tad big for a turbo.......
Old Sep 1, 2012 | 11:11 PM
Sales@Tick's Avatar
Both of those cams use lobes that would not be suited for forced induction or any amount of boost. Too aggressive.
I have three new turbo cams, and stage one would suit your needs for what you have.
226/226 .605/.605 114+3 are its specs.
Old Sep 1, 2012 | 11:25 PM
LILHEMI's Avatar
thank you! ill be contacting you in the next couple of weeks for a cam spring pushrod package then
Old Sep 2, 2012 | 02:39 AM
Sales@Tick's Avatar
http://www.tickperformance.com/tick-...r-ls6-engines/
Substitute your cam for V.1 Polluter.
