t56 and 2 step spool time with pt7675
bogged HARD on this run but its fun to pull past a trailored car that fast haha.. yes it was slow.
nitroused id love to get the 60' down but its primarily a street car and i dont want to do a drag suspension setup. i just play at the track
.. best 60' so far is a 1.703 but the car is heavy as ****... was 3720 raceweight before the iron block and dana 60. its gotta be close to 3900 i imagine with the turbo stuff/ iron block/ dana 60... gears are 3.54 and 28" tires so its not too launch friendly.gnx 7 its the msd 2 step.. i really like it, very easy to install and wire.
thanks again everyone!
I gotcha, it does really help make it fast if you can pull a bunch of timing. I have 14-15 degrees commanded and I am pulling 20* in the -38 cell and as soon as pull the timing boost is instant. Before I did this it would only make about 4 psi and would take a bit to get there.
