Procharger intercoolers!?
Old Sep 16, 2012 | 01:05 PM
Clinc's Avatar
Default Procharger intercoolers!?
Was wondering if anyone has had trouble with the procharger intercoolers not flowing well? (IE, MAJOR RESTRICTION)
I posted in another thread that I was not making the power I should be and maxing out my f1-x procharger. Come to find out after hundreds of $ and countless hours trying to figure out what was going on.. I found the inter cooler to be restrictive. I'm making 30+lbs pre Intercooler and only 15-16lbs post Intercooler. I swapped Intercoolers lastnight and had the same problem.. Actually I made about 2 more lbs of boost to the motor...
Currently running prochargers 1300hp Intercooler In a 2010 Camaro.
No boost leaks, no kinked tubing. All tubing is minimum 3"..
Old Sep 16, 2012 | 01:59 PM
gto866's Avatar
there was something about that right in the install manual - do you still have it?
to the effect of keeping the air in there longer for more cooling. did not sound good
Old Sep 16, 2012 | 02:36 PM
Clinc's Avatar
Checked the Manual and all the paper work. Don't see anything about the IC.
Old Sep 16, 2012 | 06:45 PM
skinnies's Avatar
I made 22lbs with my t76 with the procharger intercoolers, ran 142mph in my heavy ltd and rx7 went 155mph on less boost with them.
