My Final Turbo Build Setup.
Old Sep 20, 2012 | 11:45 PM
1loudTransAm's Avatar
Default My Final Turbo Build Setup.
MY Turbo Build Coming this Winter.
Front Mount Turbo Setup with A/C.
With all items
Turbonetics T7868
Turbosmart 38mm Wastegate w/ 14psi Spring
Tail 50mm Q BOV
Walbro 255L Fuel Pump Kit
Oil Feed & Return Lines w/ Catch Can are from WS6 Store.com
Design Engineering - Exhuast Wraps
Im trying to find a good Boost Controller, Boost Gauge, & Fuel Injections around 50Ibs .
Old Sep 20, 2012 | 11:46 PM
i will like to see people Turbo Engine Bay pictures that have a similiar exhuast setup, known as the ebay hotside kit. thanks
Old Sep 21, 2012 | 12:24 AM
Johnv's Avatar
Your gonna need bigger injectors than 50s if your running 14psi off the wastegate.
Go with 60s or jump straight to 80s and be done , close to same price and much more headroom.
Hope the bottom end is forged ? 15 psi should be good for 650 plus at the wheels.
Old Sep 21, 2012 | 01:22 AM
sry, im going to be pushing 8psi for now, the wastegate has a spring that 14psi
Old Sep 21, 2012 | 02:42 AM
Bigtoyz's Avatar
As Johnv recommended just get the 80's and you'll be done with them. They will tune just as easy as the 50's would. And in that same price range. Make sure to get high impedance if stock computer. Will fry computer if you get low impedance ones without the converter to do it.
Old Sep 21, 2012 | 06:58 PM
pnykillerz28ls1's Avatar
were you planning on standing up the rad or keeping it in the stock location
Old Sep 21, 2012 | 07:46 PM
MUSTANGBRKR02's Avatar
Why the 7868?
Old Sep 21, 2012 | 08:50 PM
96s-10ss's Avatar
You may need more fuel pump... go with a bosch 044
 Michael S. Palmer
Old Sep 22, 2012 | 02:55 AM
Originally Posted by MUSTANGBRKR02
Why the 7868?
i was looking into a 76m or a 78mm turbo and turbonetics is a good brand too.
more like a 340L Fuel Pump and 60 Ib injections.
Old Sep 22, 2012 | 10:09 AM
DavidPHumes's Avatar
FWIW I'd go with a Precision 7875 over the TC78. The 68mm turbine wheel isn't a great match for our cubes. It will still make good power of course.
Old Sep 22, 2012 | 01:17 PM
djfury05's Avatar
I've got a BNIB Greddy Profec B Spec 2 EBC for sale if your interested. PM me.
Old Sep 22, 2012 | 01:58 PM
i also need help with the brakes . cause the mainfold with the front mount turbo setup. it looks like the mainfold with a V band to the turbo looks likes is going to hit Brake Module in my car. what should i do
Old Sep 22, 2012 | 02:06 PM
all the installing and labor is being done by me, so saving alot of money on labor
