Anyone ever try a PT8285
Old Sep 24, 2012 | 11:46 PM
1998MysticZ28's Avatar
Default Anyone ever try a PT8285
My buddy and I were talking about this and he thinks this would be a nasty setup on one of our cars. I tried searching but found nothing. What do yall think?
Old Sep 25, 2012 | 08:26 AM
Hank Peabody's Avatar
Two other very close options since Precision reliability is not so great these days, factory Borg Warner billet 82mm turbo can be had for about half the price and is probably more reliable. Garrett GTX4508 is cheaper and genuine Garrett, but 80mm instead of 82mm. Both billet and both very comparable turbines.
Page 48
http://www.turbodriven.com/files/pdf...bo_Catalog.pdf
Old Sep 25, 2012 | 06:10 PM
LS1NOVA's Avatar
I thought of that a while ago when I came accross this beast.
Old Sep 26, 2012 | 04:34 AM
JOHNBOY66's Avatar
Page 48
I would not use a GT45R or as GTX45 as single unless your running a small cube setup like a 4.8. The turbine flow is not there. You would be much better off a GT4708. The plain bearing is much cheaper the the R and X versions and the turbine flows better.
I have not tried a PT8285. I have tried the PTE HP8284. It has billet compressor designed for high pressure ratios and it uses a turbine that out flows the standard PT8285 turbine. Not sure how it compares to the new PTE CEA turbine.
The HP8284 has been great. Made over 1000rwhp on through a locked auto, built one ton driveline and 35" tall tires.
