Boost Change
Old Apr 8, 2004 | 06:49 PM
NBM~01~WS6's Avatar
Default Boost Change
How much of a change in boost do you see in different types of weather???
Old Apr 9, 2004 | 01:44 AM
BIGBOS's Avatar
I think altitude would make a difference, I don't know about temps though
Old Apr 9, 2004 | 04:55 AM
SS00Blue's Avatar
Zero on the turbo. The manual boost controller is spring and ball. Ten pounds is ten pounds. The AF DOES get fatter in the heat and leaner in the cold, though.
Old Apr 9, 2004 | 07:34 AM
kp's Avatar
kp
Temp/barmometric pressure makes a decent sized difference with a s/c.
As observed with my car, the gauge has a recall and is very repeatable since I shift with a shiftlight.
I was seeing 8.5lbs when it was 50 degrees with a 30.4 baro (7.09 @ 98 at 2000' DA)
7-7.5psi when itwas 85 with a 30.2 baro (7.23 @ 97 1/8 - 11.27 @ 122 1/4 1500' DA)
- 10.96 @ 124 1/4 500' DA)
Three different tracks so its hard to go by ET/mph but the boost gauge doesnt lie..
Old Apr 9, 2004 | 07:01 PM
BOOSTAT4500's Avatar
My old car was a turbo MR2 and it would change by about 2 psi between day and night. Roughly 40-50 degrees air temp change. It had a HKS boost controller on it. My SC'd WS6 notices altitude more than temp. I pick up about 2 lbs. at sea level. I'm at 4500' normally.
Old Apr 13, 2004 | 11:11 AM
NBM~01~WS6's Avatar
When i first got my car i was seeing 8lbs for the first two weeks... Now i only see 6lbs... The weather is the same.... I changed my blower oil last night and i didn't see any belt dust and the belt seems to be tight enough... Should i tighten the belt a little more and try a smaller pulley...Cause my car is tuned for 8lbs and i really want to see the full 8lbs... Although when i ask speed inc they told me not to tighten the belt anymore....What would you guys suggest????
