Tick Performance Blower&Turbo Cams!!!
Old Jun 9, 2013 | 02:04 AM
  #141
Sales@Tick's Avatar
Originally Posted by 94 guy
any results on the stage 1 blower cam with a roots style blower? whipple?
I would recommend a much different cam for a positive displacement blower than the Stage 1 cam.
Old Jun 12, 2013 | 11:19 PM
  #142
Marktainium's Avatar
Looks like I'm gonna be busy this weekend!
Thanks Martin!
Old Jun 14, 2013 | 08:42 AM
  #143
Sales@Tick's Avatar
Thanks Martin!
Does this mean we will have an idle clip video this weekend along with first impressions!?!?!?!?!
Old Jun 14, 2013 | 01:22 PM
  #144
I hope so. I even did a pre-cam idle clip so you can compare back to back. Might have to skip date night tonight...
Old Jun 14, 2013 | 08:09 PM
  #145
Sales@Tick's Avatar
Awesome, it will be interesting to see the difference in idle videos, but what I really want to know about is how it performs.
Old Jun 16, 2013 | 01:51 AM
  #146
The cam is in, drove it around the block but no real test yet. The computer still needs to do some more self tuning. Sounds good though...
BEFORE...
AFTER...
Old Jun 16, 2013 | 01:12 PM
  #147
Sales@Tick's Avatar
From what I can hear it sounds good! Maybe we will get a little better video soon!
Old Jul 2, 2013 | 03:36 PM
  #148
No new video for a while. Was doing a roll on pull through 3rd gear and blew up the transmission in a glorious symphony of smashing metal parts sounds. Looking at my options. Maybe a tick magnum?
Old Jul 3, 2013 | 04:33 PM
  #149
Sales@Tick's Avatar
Sounds like you need a magnum for sure.
Old Jul 3, 2013 | 08:38 PM
  #150
RedHottG2's Avatar
Martin, I am looking at going Procharger F1A and was wondering if you had any sound clips of your more aggressive blower cams ? Thanks!
Old Jul 5, 2013 | 05:39 PM
  #151
Sales@Tick's Avatar
Here is a custom cam that I did for a 408 with a F1X. I would probably recommend a custom cam going with a blower that large, but there is a possibility after I review your entire set-up that one of the shelf blower cams could work very well with your set-up.
Old Jul 15, 2013 | 11:25 AM
  #152
awd-rwd racer's Avatar
finally got my cam in.
1993 mazda rx7
LS2 shortblock
ported 317 heads
tick performance 226/235 .605"/.610" 115+2 camshaft
brian tooley valve spring kit
trick flow pushrods
master power t76 turbo
custom 3" exhaust with magnaflow 3 chamber muffler
Old Jul 15, 2013 | 09:26 PM
  #153
a-low's Avatar
^ love to se those ls swapped rxs man. Hows byt tune working out?
Old Jul 15, 2013 | 10:46 PM
  #154
thanks..its going well. still got some bugs to work out...but everything will be good. just gotta find the time to do it
Old Jul 15, 2013 | 10:59 PM
  #155
Sales@Tick's Avatar
Have you gotten into it yet? How does it feel? That cam should work very well even with the size of your motor and the turbo that you have. Very efficient in terms of overlap.
It surprised me that it sounds that beefy though!
Old Jul 16, 2013 | 09:55 AM
  #156
yes ive done several WOT pulls. im only at 6psi right now...once we get more time to tune, we are thinking about bringing it up to 11-14 psi. pulls very nice, feels strong all the way to the top (although i have no dyno graph yet).
its wierd, it didnt sound that beefy at first, but after a few warm ups and wot pulls, it got "meaner"... i like it.
Old Jul 17, 2013 | 01:09 PM
  #157
Sales@Tick's Avatar
Lifters had to pump up. Happens all the time here at the shop when we do a cam install. Once they pump up you get full valve lift.
Is it really pulling 17 degrees of vacuum? If so it should drive like a damn dream!
Old Jul 17, 2013 | 03:48 PM
  #158
unless my vac/boost gauge is wrong, it is @17*. it has its own independent map sensor hooked up to its own vac source. so it should be correct it drives well. just gotta adjust the tune a little in the 1.5k-2.2k rpm range for the on/off throttle cruise driving..but over all very happy thus far. hoping to get it on the dyno in the next week or 2. ill post an update and dyno when we do.
Old Jul 18, 2013 | 04:37 PM
  #159
Sales@Tick's Avatar
Sounds great! I bet it's a handful!
Old Aug 20, 2013 | 07:01 PM
  #160
steveo_f8's Avatar
Ill add mine... Just recently got it fired up. This is on a 5.3LM7 with LS3/L99 turbo cam stage 1.
Open DP for now.
http://www.youtube.com/watch?v=sxbKo...ature=youtu.be
