max boost on pump gas?
to steer this back in the direction it needs to be....
we all can pretty much agree that a decent size intercooler is a must if you want your engine to survive multiple amounts of WOT boosted runs. with boost in mind with 91-93 pump gas, which pretty much EVERYONE with LS motors run since it recommends it on the gascap from the factory and generally is widely excepted as better to run on when boosted, what are resonable levels of boost guaged around a 9.5 CR since thats the inbtween CR area that most people seem to be running when running boost on street cars.
and dude, if you run 87 gas boosted and runnning good times, all the props to you, but most of us would like it if the discussion got streered back to most peoples applications that run on 91-93 range on the street.
I don't neccisarily agree. You don have to run an intercooler at all, or even that octane level. It all depends on your setup and boost. Intercooling, meth, high octane fuel, race gas, and lowering the CR are all ways to keep away from detonation. They don't all have to be done. Just what is necissary per the setup.
Tell you what, Ill be in Abu Dabi sometime next year, ill come see this heat box scream and make all of about 850.
AS you say though, the setup dictates the need for types of parts.
Theoretically, you could just make it all up with CR, and run just premium gas, and no meth, no intercooler or race gas.
My point is that a car without an intercooler is not lagging if it is running away from detonation. I think I've made my point clear by now. I just wanted you to understand that not every component is necissary.
the old "you gotta learn the rules before you break em" theory. funny a music teach talk me that long ago and it applys to pretty much everything in life. that and the KISS method.
ive always been taught that any heat you can get out of the intake before it hit the combustion chamber is a benefit over all to power.
I myself am using a large FMIC, 93 pump gas, 317heads (9.7ish CR with LS9 gaskets), rear mounted with a T76 to get everything going. but thats for my mild street setup. sticking to under 650hp. Like you say, its all in setup
but we run methanol water mix now and never have a issue on 25psi or so
going to be switching to strait methanol soon as i think that might be one of the reasons our cars are lacking in the horsepower dept
A 4-bolt head with LS9 gaskets and studs should be able to run 23-24psi or so without pushing water as long as everything else is up to task. But you wont get this out of 93 pumpgas.
This will go through a triple disk cluck, and a fully built tr6060 manual, and so much crap. Ill start a build thread soon
for those who subscribed, ill let you guys know what we end up running as far as boost and how much timing and how much power it made.
