Harlan, question on vette fpr
im assuming by your other posts you did remove the stock regulator from the tank right? I saw you write "if you remove the stock regulator from the tank, you can then use rubber hose..." but i never saw you write i removed the stock regulator.
keep us updated on the progress, my next purchase is some 9798vette rails.
and question, how did you connect the vette rails, to your hardlines, were you able to just use 2 of the f-body hardline to rail rubber hoses ?
Ryan
I used the stock fuel line to the vette rail "in"....used a rubber hose from the vette return to the hardline.
im sorry.
