Twins on a 4.8?
Old Oct 28, 2012 | 01:41 PM
BLACK-00-WS6's Avatar
Default Twins on a 4.8?
I am building a low mile 06 4.8 and was considering going with twins. I have a new GT45 but dont think it will reach my goal. looking for 700-800 RWHP on E85. running stock 706 heads. so far I have,
BTR custom ground hydralic roller
BTR dual springs with titanuim retainers
super victor intake
edelbrock elbow
90mm TB
160# injectors
comp magnum pushrods
etc...
Looking for proven combos that are still streetable. thanks
Old Oct 28, 2012 | 03:40 PM
lavoy's Avatar
twins in the 4.8 world are few between. but i tow have been looking into doing this on my next build. currently i am running a 4.8 that makes 700 whp with a 74 mm turbo. i would look into doing something in the 62 mm range with a .68 -.78 exhaust AR in a t4 format. this will give you the cfm to clear 100 with ease and still spool quick.
Old Oct 28, 2012 | 03:49 PM
whats your combo? how does it spool? thanks
Old Oct 28, 2012 | 04:51 PM
lavoy's Avatar
junk yard 4.8 stock bottom, worked over 4.8 heads and ls6 cam fast intake and stock ls1 throttle body. 74 mm precision turbo with 96 ar . spools quick enough but on the foot brake i can only muster around 6 psi with my tightish converter. id rather have a tight converter my self so i want to go twins next time so i can still flow enough cfm but also be able to make more psi on the foot brake.
Old Oct 29, 2012 | 12:31 AM
65chev's Avatar
Default 4.8L Twins
I'm also considering twins on a 4.8L or 5.3L. I've been looking into GT30's - GT35's with a .6x AR. I think the GT30's would be plenty, it's just figuring out what exhaust wheel would work and not cause to much back pressure.
Old Oct 29, 2012 | 01:07 AM
71 chevy's Avatar
I had twin 61s on a 4.8, running e85 and it was very laggy. It took about 5 secs on the Tb to build 10 psi.it had a very big cam so that hurt the low end a lot.only thing id say is between going too small and going to big,err on the side of too small.
