5.3+turbo+hot cam?
Motor for sale buy me for $900 5.3 iron new bearings, honed, ported truck heads, GM hot cam and yellow valve springs (believe ls6 springs) ???
Looking at maybe a 80-88mm turbo auto setup
Thoughts for motor setup?
Personally I am looking to build a 5.3 using the Comp XR259HR or a custom grind using an intake lobe similar to the LS6 (204 duration / .555 lift) w/ an optimized version of intake lobe of the Comp 265HR (212 duration / .558 lift) on exhaust. Either the XR259HR or my custom blend should provide 15-16 degrees of negative overlap which helps with low end power and possibly spool too.
I plan on speaking with Pat G. to help me spec and build a cam around the beginning of the year to be sure, but my aim is to build a strong (480-500 rwhp) street car-thus my emphasis on smaller cams that will give me usable low-end torque and power....
Take cam advice here carefully because many of the guys on here race and may point you in a different direction (excessive duration and / or lift) than you might really want to go for a street driven vehicle.
