plugs gap change+same timming table=pushing water???
Old Nov 8, 2012 | 10:12 AM
Ls-x's Avatar
Originally Posted by WSLN 6
Just curious, what were your intake air temps when it pushed water? The reason I am asking is that I learned the hard way that injecting a lot of meth with iat temps under 70f would lead to improper meth distribution and random combustion from cylinder pressure. A little hard on heads/rotating assembly and pushed a lot of coolant out, even with no knock and a safer tune with xfi.
Just a thought.
it drops to high 60's to low 70'
i am interested to hear about your experience please .
Old Nov 8, 2012 | 11:30 AM
Slowhawk's Avatar
LS1Tech Sponsor
I think you probly already traced the head gaskets before. The 18psi just finished it.
I don't think it has anything to do with the plugs.
Old Nov 8, 2012 | 11:46 AM
Ls-x's Avatar
R you saying that the gasket could'nt hold itself under load or it was the time for it to give up ??
Thanks
Old Nov 8, 2012 | 01:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
It means you can hurt them when it overboosted or ran lean before. It will trace through the gasket.Then under higher boost it will push some water.
Pushing water is very normal on high boost cars. Some people judge how much on each pass if it's time to change the gaskets.
Pull the heads off. Clean them up. Install new gaskets and I would copper spray them. Should be fine at the 18lbs after IF the tune/octain is good.
Old Nov 8, 2012 | 02:07 PM
Ls-x's Avatar
I will post some photos after i pull the heads .
Thank you
Old Nov 10, 2012 | 11:32 AM
Ls-x's Avatar
Old Nov 10, 2012 | 05:09 PM
Louis's Avatar
She's pissed!!
Don't run so much boost on that tune up, or turn the timing down 2-4*
Old Nov 10, 2012 | 07:35 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah and that is number one not the normal one for lifting from my experience. GL!
Old Nov 12, 2012 | 12:48 AM
Ls-x's Avatar
I am going to creat a more friendlly timing table and hope this never happen again .
Thanks for all of you guyz who shared there experience with me.
Old Dec 2, 2012 | 09:44 AM
NOS4EVER's Avatar
All the best brother I hope I get mine reedy to rumble soon just waiting to sort
Things with the registration first than installing the twins.
Old Dec 2, 2012 | 03:10 PM
Sales@Tick's Avatar
I'd be curious to know what your timing table looks like and not just what your running at WOT/high rpm.
