ABS Module Delete Guys, Normal Lights on Dash and Does Your Cruise Control Work?
Old Nov 9, 2012 | 08:54 AM
Tally TransAm's Avatar
Default ABS Module Delete Guys, Normal Lights on Dash and Does Your Cruise Control Work?
Gonna put this here also since I spend most of my ls1tech time here and lots of guys have deleted their ABS
Deleted my abs module during my recent motor swap/engine bay clean up project and just want to verify what the normal dash lights are.
I have ABS INOP (been there since i installed the 9" a few years ago), BRAKE, and SERVICE VEHICLE. I believe all those are normal but just want to verify.
Also I noticed my cruise control is not functioning. Can anyone verify on their car as well if they have working cruise control with an ABS Module delete?
Trying to figure out if the cruise control not working is a side effect of the ABS removal or if I have a different issue I need to find. If it is as a result of the delete has anyone figured out how to bypass it?
Thanks
Old Nov 9, 2012 | 02:12 PM
slow67's Avatar
Gingervitis Addict
I removed my ABS and my cruise works fine. Check the conversion section on what wires are needed for the cruise control module, IIRC they have been the same since like 1994 (as far as the 4th gen ones).
Old Nov 9, 2012 | 02:46 PM
got-a-ls1's Avatar
i have an auto harness with a t56 and also deleted abs, my cruise works perfectly. annoying lights are on but im gonna fix that this time when i remove the column to swap pedals again.
Old Nov 9, 2012 | 04:11 PM
LS1CMR's Avatar
My cruise does not work and I deleted my ABS. I had the same lights on the dash. I took the bulbs out to get rid of them. So there is a way to have the cruise work. Details if anyone has them.
Old Nov 10, 2012 | 07:52 AM
got-a-ls1's Avatar
i think you have other issues. my cruise works fine with abs delete with nothing special at all done
