procharger F1 bracket questions .
Old Apr 12, 2004 | 11:55 AM
XtremeLover1999's Avatar
Default procharger F1 bracket questions .
Sup , i would like to know where i could find a bracket for an procharger F1 that is normal rotation ( not revers like on the fbody ) that should work on an ls1 motor . I remember i saw one just the way i like it but i think it was an vortech . I think it was from the guy that ran 8.50 with c5 motor and heads . I would like it to be on the driver side , normal rotation . I can't find the pic from the guy that went 8.50 anymore . I want it like that cause it would be easier to fit in an S10 and i already have the normal rotation unit . The car already have ACCEL dfi gen7 , 75 lb/hr injectors , 3 bar map , fuel cell and fuel lines and SX regulator with walbro external fuel pump . I would have to order an other one . And i'm looking into an iron block motor . So i would like to know if there is any hotrodders that have ls1 motor with an procharger ? I need some other idea .
Thanx , let me know
Old Apr 12, 2004 | 05:49 PM
blu00rdstr's Avatar
You might want to check out A&A Corvette, they have one for LS1/C5 that might fit.
https://www.aandacorvette.com/images/items/MVC-006F.jpg
Old Apr 12, 2004 | 06:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
So you would mount the blower where, up high?
I am running a custom YS Vortech setup down low where the alternator would be normally.
Old Apr 12, 2004 | 06:15 PM
Thanx blu00rdstr . Is that high mount or low mount ?
pro stock john , I need it to be high mount because it can't fit low because of the steering box in an S10 body . I already have a bracket that would fit on regular small block holes on the heads . I could probably make an adapter . Where is your bracket mounted at , on the heads or block ?
thanx
Old Apr 12, 2004 | 07:27 PM
LS1Tech Co-Founder
the heads
