new to LS1 tech
Old Nov 18, 2012 | 06:17 PM
custertruck59's Avatar
Default new to LS1 tech
I am building a 59 Chevy pick up with a Nova subframe. Using a 5.3 motor and want to do turbos. Any body got ideas for what parts I should use?
Thanks,
A.J.
Old Nov 18, 2012 | 11:10 PM
typhoon1015's Avatar
do some searching around this section, lots of info,
Couple questions:
What are your goals?
What is the truck for? drag? street? autocross?
Any wants to need? like intakes etc?
Budget?
What kind of fab skills do you have?
to start, I would do flipped 2010 camaro manifolds, and either gt3076 or gt35's for turbos. 80 lb injectors, HTptuners, supporting fuel system mods, Head studs, ls9 gaskets, a cam( either used or a custom spec depending on budget, supporting valve springs, treadstone TT intercooler, RPS BOV, a pair of wastegates of choice ( tial, JGS, precision)
Do an 4l80e with HD2Kit and a good 3 disc lockup stall.
Crank up the boost if its too slow( i doubt it will be though)
