Procharged returnless fuel system problems on H2 hummer kit
Ive got a procharger 03 hummer kit. 03 hummers used a return style fuel system. Procharger doesnt have a kit out for the 04's yet because its a returnless fuel system.
Can I just throw 42# injectors and a inline fuel pump on the thing? Im just going to send the ECU to Ed Wright to setup the computer, as i dont have ls1edit or anything for a 04.
Ive already put one procharger on a 04 hummer, but i used stock injectors with an FMU and used a custom check ball fuel system setup that only turned on the inline pump under boost which then activated the flow to the FMU. and it worked fine, but id prefer to just do it with injectors..
Mike
If you can tune it to the larger injectors that is a much better way then an FMU by far. I have 42lb SVO injectors on this car with the ATI inline pump and I can get 10:1 a/f on this one as well on the in-car wideband so its plenty of fuel for 7-8psi on this car.
