New Project... need advice, opinions and help
Old Dec 13, 2012 | 09:44 PM
00firehawk's Avatar
Default New Project... need advice, opinions and help
I have a 405 LQ4 stroker that I want to turbo. I have acquired a 70mm .96AR turbo for this project. This is going into a #71 Firehawk and thinking of going rear mount due to not having to chop on the car. Motor is built to hold 25+psi
This is a M6 car that will be using 3:73 gears ( unless I need to do a diff size)
I also have a stand alone meth kit as well.
Do I go air to air or air to liquid inter-cooler?
Recommended Waste gate?
Recommended blow off valve?
Boost controller?
Does anyone sell a kit to run a rear mount or do I have to piece together?
End state: As much power as I can squeeze out of it!
Old Dec 13, 2012 | 09:53 PM
jridenour31's Avatar
That turbo is way too small.
Old Dec 13, 2012 | 09:55 PM
00firehawk's Avatar
I know of cars with 70mm's and 76's with 408 motors and do pretty good. Why would it be too small?
Old Dec 14, 2012 | 10:51 AM
00firehawk's Avatar
Bump...... anyone?
