s475 on untouch ls1, what to expect with 9psi
Old Dec 21, 2012 | 07:56 PM
James@ShorTuning's Avatar
Depends on the dyno! Stock LS1's on mine only make 265-275 and I've done a few setups similar to yours only they had non stock camshafts and they were in the mid 400's. What year car/LS1 is it? 01-02 car will make a little more power just due to the ls6 intake flowing better. 98 car will have more trouble due to the crap heads on them.
Either way it'll be a fun setup for sure!
Old Dec 21, 2012 | 09:07 PM
TrickrTreat's Avatar
Agreed james. It definitely depends on his N/A dyno number. My numbers are based off his car being a stick, strong motor and on a dyno jet (guessing).
If hes on a mustang dyno, and its not a strong motor "factory beast" , then hes probably going to be somewhere around 440-450.
all comes down to how happy the motor is, and how the tuner manipulates the tune with the meth.
Old Dec 21, 2012 | 09:58 PM
Wicked69's Avatar
I used stock lifters, pushrods, rockers and I have been running 25lbs of boost and still holding. Have it tuned down to 15lbs now. This is on an engine with 180,000 miles. No way I would bother with pushrods.
Old Dec 21, 2012 | 10:14 PM
cory32690's Avatar
Was that on a ls1
Is this on a ls1
Old Dec 21, 2012 | 10:28 PM
mrstepheneades's Avatar
The car is a 2000 ws6 6speed....... i had a previous 2000 years ago made 324 on a dynojet with muffler delete and free mods lol.It was also a six speed.
Old Dec 21, 2012 | 10:29 PM
It will also more than likely be tuned on a mustang dyno.
Old Dec 21, 2012 | 10:37 PM
jridenour31's Avatar
Pushrods are $100. There's no way I wouldn't throw a set in, especially with the t56. It's cheap insurance. The lifters are fine and so are the rockers with a trunion upgrade.
Old Dec 21, 2012 | 10:53 PM
95maroz28's Avatar
i made 501 md with 6psi baby cam, springs and ud pulley on otherwise stock 98 ls1 6 speed. We were out of stock fuel pump and inj but probably could have made a little more. Stock motor should make 500+ 8+lbs. Think i picked up roughly 25hp/lb
Old Dec 22, 2012 | 04:56 AM
That's good to hear. I plan on putting a single 255lph pump in so as not to have that issue and at least 60 lb injectors. Cant wait to get this thing together.
Old Dec 22, 2012 | 07:29 AM
if decided to do cam and all what is a good out of box cam setup to go with guys??? something i could use with the forged 6.0 later as well.......when ls dies!
Old Dec 22, 2012 | 10:49 AM
95maroz28's Avatar
if you plan on blowing it in a few pieces might be better to wait on the cam unless its cheap enough. When mine let go a bunch of debris got caught on the rollers scarring the cam. Was just a 100$ cl special and 170k motor for me but just a thought if you want salvage anything
i did swap a 255 pump in shortly after and ran 8-9lbs for a year and 20k
Old Dec 22, 2012 | 11:02 AM
  #32
CordiaDOHC's Avatar
Good to hear some of this. Im currently turbo'd with a 98 A4 and looking to make a few upgrades that the previous owner shouldve done.
Old Dec 22, 2012 | 03:02 PM
  #33
i did swap 255 pump in shortly after and ran 8-9lbs for a year and 20k
Yes I may just wait on the camshaft because the stock ls1 is a time bomb lol
Old Dec 22, 2012 | 03:08 PM
  #34
Why do you think it is such a time bomb? With a good tune it will last quite awhile.
Old Dec 22, 2012 | 06:13 PM
  #35
Idk just always think the worst i guess lol. Motor has 128 thousand on it..... good oil pressure though.
