Help! Will my current cam work with a supercharger?
Old Dec 25, 2012 | 11:38 PM
redssmaro's Avatar
@cam72aro so u would have 2 walbros pumps and the stock one? And I've heard stopping that gas tank is no fun. Is there any easier way to put the pump in? Or one that is located around the fuel lines instead of inside the tank.
Old Dec 25, 2012 | 11:52 PM
I8UR4RD's Avatar
there are plenty of threads showing you how to swap pumps, and some ever show how to plumb the duals. You can either cut a hole in the rear and pull it from the top without having to drop it or drop the tank out completely. Either way its not as bad as youd think. When it comes to fuel I let Lonnie take care of it. He'll take care of you too. A single racetronix may be all you need unless you plan on going past 600rwhp.
Old Dec 26, 2012 | 10:35 AM
redssmaro's Avatar
Alright so a single racetronix pump inside the tank is what I'll be going with. And I'll be cutting up a hole to get to the gas tank. Looks the easiest way. Thanks for all your info.
