Pro Flo XT...install help needed.
It does look bad *** though!
PN 3629 for the rails
http://performanceparts.com/images/p...1_20100331.jpg
Also if your running the truck TB you will need a spacer for the IAC or do some grinding on the intake to make a bypass for the IAC. I bought the spacer, works fine.
I did not know there were Pro Flo rails. That sucks. I have edelbrock rails and thought they were the same for both intakes. I guess I will have to get the Pro Flo rails.
Thanks.
You can get little 1/2" strips of AL at Lowes, i use that since its bendable.
A couple close up pics of the rail mounted if someone has them. Thanks.
2nd issue is also because the throttle body sits so low I was not able to use my intake pipe. I trimmed a little here and there and the next thing you know I had nothing left. lol Anyways, I am just going to take one of my 90 bends and make it as small as I can, cut a hole in the side and re do where my BOV is.
I think this is going to look a whole lot better but I do like how clean everything looks with it.
