Truck manifold gaskets
Old Dec 28, 2012 | 08:58 PM
kpennepacker's Avatar
Default Truck manifold gaskets
What are the guys using for gaskets on the manifolds that go to the turbo merge pipe. Can't be doughnut gasket can it?
Old Dec 29, 2012 | 07:35 AM
Camaro9969's Avatar
Not sure what exactly you mean but any metal gasket will be fine
Old Dec 29, 2012 | 08:38 AM
no1izspeshl's Avatar
IIRC, one side of my merge pipe required a doughnut gasket.
I just went to napa and had them get me the exhaust gaskets for a 2005+ 6.0L truck.
Old Dec 29, 2012 | 09:51 AM
WheelsUp84z's Avatar
I just got the SCE copper ones from Kurt Urban when I bought the water vapor setup.
Old Dec 29, 2012 | 11:10 AM
98Camarod's Avatar
Copper spray gasket. No leaks and I've taken them off several times. I just clean it off and respray.
Old Dec 29, 2012 | 06:32 PM
I need to know what to use from manifold to merge pipe. Oringally has a doughnut gasket. I was wandering if that was what guys were using or if there was another trick
Old Dec 29, 2012 | 09:04 PM
The above stated things are what you use.....
