Injector size??
Old Jan 1, 2013 | 02:47 PM
Thackdaddy43's Avatar
Default Injector size??
I am going to turbo my firebird here soon and right now I have 30lb injectors already installed. With the turbo kit I am going to I only push about 8-10 psi. Will these injectors hold up or am I going to have to get bigger ones??
Old Jan 1, 2013 | 09:50 PM
playtoy's Avatar
You will need bigger injectors. At least 60 lb/hr depending on your set up.
Old Jan 2, 2013 | 09:27 AM
98Camarod's Avatar
What is your current setup? I had 42lbers on 7lbs from a t70 and a mild cam and maxed the injectors. Depending on your goals, I'd just buy injectors that suit your end goal. I wish I would have done that from the beginning.
Old Jan 2, 2013 | 11:18 AM
Ok sounds like I am getting bigger ones then.. Thanks for you help guys.
