3 bar map
Old Jan 2, 2013 | 11:55 PM
Leon Garcia's Avatar
Default 3 bar map
can I use a 3bar for only 15# of boost any recommendations ls6 intake
Old Jan 3, 2013 | 12:15 AM
Blown06's Avatar
8 Second Truck Club
You could use a 3-bar with no boost if you wanted. So the simple answer is yes.
However, I think you lose some resolution in the ve table if 3-bar is not needed.
Old Jan 3, 2013 | 06:19 AM
stevieturbo's Avatar
As long as the map sensor is calibrated to your ecu, then yes you can.
