LSA Heads / Components Questions - please help!
These part#'s in particular from GMPP:
12605223 - 2.165" Intake Valve, 8mm Stem, Solid Stem, LS 15 Degree
12612427 - LY6 1.59 High Temperature Heavy Duty Inconel Exhaust Valve
Then, I found the LSA cylinder head assembly and thought maybe I should just use these with only a valve spring change.
12626958 - GMPP LSA Cylinder Head Assembly
I have found the 12605223 as a direct replacement for the LSA head intake valve, but I can not confirm that 12612427 is the exhaust valve used in the LSA head assembly. I don't know why GM would list all the part for this cylinder head but not the exhaust valve - it only says "Premium steel intake and exhaust valves"
I like the LSA heads because they are made with the roto-cast method and use a better alloy for boosted applications - if I can confirm the exhaust valve from the factory is the GMPP inconel one I listed above then I would say it's worth it to go for these heads.
Otherwise I will just keep my LS3's and change hardware - has anyone else come across this?? Thanks
