valve cover breather mods
Old Jan 11, 2013 | 07:58 AM
overhere's Avatar
Default valve cover breather mods
Was wondering if any one was modifying the baffle on the valve covets after adding larger breather connections?
Old Jan 11, 2013 | 09:26 AM
WheelsUp84z's Avatar
I just put 2 passenger side VC's (ones with the fill port) and used the metco adapters. http://www.metcomotorsports.com/prod...d=MBR0003-10AN
Old Jan 11, 2013 | 09:36 AM
overhere's Avatar
I was more concern with the stock ;baffle on the inside of the cover. I put a an fitting on the driver side cover. And the stock internal baffle only has one small hole in it. Wasnt sure if it was enough or i should put another hole in it
Old Jan 12, 2013 | 09:23 AM
ss1's Avatar
ss1
Those Metco adapters are slick! I've never seen those before.
