Procharger guys... Header wrap ?
Old Jan 15, 2013 | 11:14 AM
conan's Avatar
The headers will be bolted to the heads before I stuff the engine back up through the bottom of car. Hopefully that wont be a issue.
Old Jan 15, 2013 | 05:48 PM
sweet99ss's Avatar
This is why I wonder if you could do it with the exhaust on the car. My headers are welded to the rest of the exhaust and pulling the exhaust would be a real beotch
Old Jan 16, 2013 | 07:03 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Make sure you allow room for spark plug access. Lock-wire, normally used for securing fasteners, works well for securing the ends of the wrap. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 16, 2013 | 07:06 AM
LS1Tech Sponsor
You might end up with a back ache but you should be able to wrap most of the headers with them installed on the car. A lot of it can be done from under the car. Bob
__________________
Old Jan 16, 2013 | 08:31 AM
conan's Avatar
Thanks for the heads up on the plugs. Are you referring to "safety wire" that you install where you have drilled holes in bolt heads and nuts ?
Old Jan 16, 2013 | 09:16 AM
LS1Tech Sponsor
You're welcome. Yes I am referring to the safety wire, just bend over the ends when you're done so you don't cut yourself on them and safety wire works very well and cost a lot less. Bob
__________________
Old Jan 16, 2013 | 09:28 AM
BudRacing's Avatar
I used hose clamps on the primaries and the collectors. It's a much more solid option than metal zip ties.
Old Jan 16, 2013 | 09:40 AM
conan's Avatar
Thanks bob.
I thought about using hose clamp but was concerned about the bulky screw and housing of the hose clamp getting in the way when changing plugs. Also I want this to look as clean as possible.
