Who has an eboost street setup?
Old Jan 12, 2013 | 04:01 AM
80gus's Avatar
Default Who has an eboost street setup?
Im still in the process of putting my truck together, i have fitted a tial 44 Wastegate, and want to use a eboost street. the goal is to reach 12psi, maybe 15, ive fitted a 7 psi spring, and want to know what method to use for connecting the solenoid.
page 7, 8 ,or 10?
http://www.turbosmart.com.au/wp-cont...psi-MAY-12.pdf
Old Jan 12, 2013 | 04:51 AM
stevieturbo's Avatar
You can try "Two port, single solenoid, single turbo connection Method (1)" first of all
If this prevents you running the low boost level you desire, then you will need to revert to "Single port, single solenoid, single turbo connection Method"
Old Jan 12, 2013 | 08:43 AM
Superman09's Avatar
LS1Tech Sponsor
What Stevie said. I run that set-up on my car and don't have any issues!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jan 12, 2013 | 02:58 PM
80gus's Avatar
Thanks lads.
