rear turbo bracing options
Old Jan 17, 2013 | 10:23 AM
JoshuaGrooms83's Avatar
Default rear turbo bracing options
was wondering if anyone has some pics of rear mounted turbo bracing. Trying to get a good idea where to mount it and keep that puppy tucked up there nice and tight to keep it from bobbing around.
im just not sure where on the turbo to use and where on the car to mount it
Im using a On3 T76 turbo. im gonna have a bullet muffer right after the turbo and then out the normal side. Im gonna have a wastegate dump pipe that routes to the driverside and the filter will be up in the fuel fill up area like STS has it. ill do alittle bit of modifications to make it more efficient but all in all it will be very simular. I just want the turbo to sit up as high and tight as possible
Old Jan 17, 2013 | 11:28 AM
ZL1Killa's Avatar
i'll take a few good pics of what we did for my 76mm. I like it and its definitely not going anywhere. We did use the top panhard (Stock) bar for holding. My lower panhard bar I have replaced with aftermarket.
Old Jan 17, 2013 | 11:45 AM
yeah same here, i have that UMI panhard support bar.
