holset h1c question
Old Jan 19, 2013 | 09:03 AM
drago1217's Avatar
Default holset h1c question
So I found a used one in good shape at a good deal. I've tried searching but not a lot of info for an ls1 application. would it even be worth it. If i'm not mistaken out is only rated to 500hp. Is there anyone that has pushed one past that. Thanks for any info
Old Jan 19, 2013 | 09:20 AM
drago1217's Avatar
Just some info on the car. I have 228r Cam, stage 2.5 5.3 heads, fast 90/90, m6, stage 5 monster clutch, 4:10, 42lb injectors, Racetronix fuel pump. Looking at running low boost. Stock bottom end. At least would it be worth it to get the h1c, build the turbo kit, then upgrade the turbo later? Budget diy truck manifold kit.
Old Jan 19, 2013 | 09:33 AM
TheLS1Lover's Avatar
Can't find much info myself. Might check around some of the Cummins forums. I know the DSM guys use them on 2.0L motors so its more than likely too small.
