Cam/heads or turn boost up
Old Feb 10, 2013 | 02:07 AM
Mrmooney's Avatar
Default Cam/heads or turn boost up
Car made 543rwhp/565rwtq on 10Psi pump gas ( 1.19 correction factor, we are at 5600+ ft above sea level )
Motor is stock 99 ls1 with rod bolt and head studs.
Questions is whats next. Ordering a rear soon and now that i've got some rubber under it want to turn it up so ,
heads
cam
or turn it up. I need to get a different waste gate spring and want to switch it to E85. My goal right now is 650 ( with the correction factor ) to the tire.
Can I get there with just turning the boost up and running E85 or should I look for heads and a cam. Heads are stock 853's turbo is 76mm precession.
thanks in advance.
Old Feb 10, 2013 | 11:14 AM
Silver_TransAm's Avatar
I would Turn up boost and go E85
