aluminium block vs iron
Old Feb 10, 2013 | 09:28 PM
lunati397's Avatar
Default aluminium block vs iron
im building a turbo 6.0 I already have a 2002 LQ4 ls3 heads ls9 cam t78 turbo reverse manifold setup I have intentions to replace the rod bolts and regap/replace rings
Now the issue is I just had a l76 or the 2008 vortec max engine just fall in my lap
which would be the better builder I know the newer one have far better internals but the LQ4 has the iron block I plan on boosting to around 15 18 psi max average roughly it will see 12 to 14
I will have meth 80lb injectors complete fuel system and already have holley hiram intake and 102 tb
which one should I go with
Old Feb 10, 2013 | 09:37 PM
SLCviaAK's Avatar
How much do you want for the one you don't utilize? Where are you located?
Old Feb 10, 2013 | 09:39 PM
lunati397's Avatar
Clovis NM 12 hours from you and it will be for sale
Old Feb 10, 2013 | 11:53 PM
SirNemesis's Avatar
I don't think you'd have any trouble with either if you are planning on leave the bore standard (or close to standard).
Old Feb 11, 2013 | 01:54 AM
stock48's Avatar
9 Second Truck Club
The L76 has better rods, and is a ton lighter. Downfall is they are usually dod but not hard to convert. If engine has around 100K 0n it rings should be ok.
Old Feb 11, 2013 | 03:25 PM
TheLS1Lover's Avatar
I'd do the Aluminum, if it has DoD Tick sells a delete kit.
Old Feb 11, 2013 | 05:06 PM
lunati397's Avatar
decided to go with the aluminium l76 and sell the lq4 LS3 heads and my painless harness and get the Holley hp setup
Old Feb 12, 2013 | 09:39 PM
lunati397's Avatar
picked it up today not a bad trade a 5.3 intake to pan with harness for a L76 complete intake to pan and it had 30k on it still looks brand new
 Michael S. Palmer
