What heads and cam for vortec ?
Old Apr 18, 2004 | 08:19 PM
02SOMWS6's Avatar
Default What heads and cam for vortec ?
Not sure which heads and cam to go with , I need some help.I was thinking of the patriot stage 2 and going with a smaller pully to take advantage of the drop in compression with the truck heads.I see asp has a 2.5 pully.As far as the cam I'm thinking split duration 218/224 527/534 114 lsa .Thats what I'm thinking not sure. Any ideas?
Old Apr 18, 2004 | 11:18 PM
Crunch's Avatar
You are on the right track. That is the perfect heads & cam for stock cubic inches and the Vortech kit. You may want to go with the 2.75" pulley from Vortech, because that cam peaks at 6500RPMs. That way you won't overspin the blower and shorten its life. With a good tune you should be just under 550RWHP with 10:1 compression, 530RWHP with 9:1
That should be good for mid-10's.
